2004 GMC Sierra 1500 brake problems
Maybe you jammed the pistons in a bit an angle when you pushed them in?  Or perhaps pushed some crap from the caliper back into hose and blocked it (the hose may already have partially failed as well, they can collapse internally so fluid only flows one way).
I'd replace the calipers if they are original, it's a common thing to happen on old parts.
6 hours ago, Kgrr said:
04 GMC Sierra
I replaced pads on the rear, after which the rear brake calipers won’t release.
It will either be the caliper or the rubber brake line collapsed on the inside. Make sure when you install it, you install it with the bleeder screw on the top. Sometimes you will receive the wrong caliper or if replacing both calipers you can install it perfectly fine upside down. It will not bleed if the bleeder screw is not on the top. I have seen this too many times not to give you the warning.
Any recommendations for a caliper upgrade? Everything I’m reading says these calipers always seize, and since I’m replacing calipers why not upgrade to something better?
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 404 Guests (See full list)
