19 Suburban Vent and Temp Controls not working but half the time
Dshoaf3152
Has anyone with a tahoe or suburban experience any issues with the vent controls or the temp controls only working half the time.  Got my suburban used (still factory warranty) at the start of Dec 2019.  Dealer has had it probably  6 times or more now and the total time they have had it would i be around  60 days or more and it’s still not fixed after all the visits.(i didn’t buy it from them but they are working on it under warranty for me.    They are a great local dealer and a good group of guys but from what i gather are at a loss for words and i was told the GM techs at corporate are as well.
issues:    Some days the vents are stuck on a position and won’t change and the temp may not work and blow only cold and some days we have had it blow freezing cold on driver and hot as hell in the rest do the car.  Some days the temp may work but the vents are stuck on the floor or defrost. It can last all day or sometimes possibly 10 minutes and then it’s like it switches over and works.   Its went the most 7 days without and issue but then it started back with the same problems.
i’ve been on the phone with GM with questions about the warranty and so on but it’s proving nothing more  but to infuriate me each time with the Sr Manager that  has my case.  my question has been so if the original issue is never fixed and thus continues on till my warranty is up in 3000 miles what then.  his response was your warranty is up and i said but it’s never been correctly fixed.  he said they’d play it case by case.   i want to have them buy it back because now everyone we do get it back it’s just a waiting game on how long til it messes up.  i have a feeling it’s about to be lawyer time with the warranty act law.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
