Cruise control help
I bought an 07 Silverado new body with 4.8. I got it at a good price but this guy was a flipper and messed things up I believe.
my cruise control lights up but won’t work.
I replaced the brake switch no help.
thenninremembered it had a led third brake light. I changed that and no help
today bought a new cruise control switch and no help
what Can I  do next? Any ideas?
I'd scan it.  See if you have any DTCs anywhere.  Also, check the sticker in the glovebox for RPO code K34.  That is the code for factory cruise control.  Is the switch on the left side of the steering wheel next to the airbag?
Yes it’s on the left side. I just ordered a scanner. It will be in on Saturday. I’ll update then. Thanks.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
