Power steering pump recommendation?
Need to change the power steering pump on my 09 silvy 5.3L. It is leaking and whining during acceleration.
Any particular brand you guys recommend? OEM? I'm reading mixed reviews on the cheap refurb units a lot of people saying they are noisy. Thanks for any input!
Sent from my SM-N975U using Tapatalk
Ac delco and be done with it. Been there done that just a few months ago with 03 burb, if you are planning on keeping the truck it’s worth the money. I bought a rebuilt cardone pump from my local parts store because that’s what they sell, I’m not a fan of cardone, worked fine but it was so loud it was unbearable. It’s not a terrible job but it’s not really fun to do the second time.
