I’ve seen a diagram of where the pcv Valves are located on a v8, but it doesn’t appear to be in the same place on my V6.  Any help is greatly appreciated.
  • 8 months later...
30 minutes ago, erasmoviera said:
its on the driver side back valve cover, remove black hose(its plastic light grey)
Yep, what he said.
    • I have 2 choices.
