Holds vacum , no leaks found , loses charge over night
MarcuM
2016 Silverado 5.3 cc
ive been putting a large can of charge in it every other day
first I put the sniffer to it and nothing
I ran dye through it and under Uv light I can’t find any leaks anywhere not even around the condenser
 , pulled vacum and it set at -20psi for 25mins
put 40psi of charge in it and got 2 days before it was gone
works great as long as the charge is above 25psi
I have did this for a solid year now while I worked up north but now I’m transferred to Atlanta so I need my ac
ive changed the valves out
truck has 160,000 miles and 6,000 hours on it and I can’t give it up for few days to a shop becuase it’s my life line for work
anyone had this same problem ?
If you can't see it then it's likely the evaporator. No real way to tell unless you pull the dash but if it's losing a full charge overnight it should be a big leak.
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 426 Guests (See full list)
