Hum noise at 50+mph
Hey guys, I hope I'm not double posting but I couldn't find anything about this via search.
I replaced my rotors and pads on the front late last year before the snow hit. I'd noticed after a bit that I was starting to get a "humming" noise from the front at 50+ mph. I can hear it and very lightly feel it in the gas pedal (so I think, could be my mind). It sounds like this (best try):
  • 2.5-3 seconds nothing
  • 2.5-3 seconds humming
It sort of feels like something is dragging/rubbing. I'll drive on the highway for an hour and then get out and touch the brakes to see if the rotors are hot, and don't notice anything. There doesn't seem to be an issue with the pads wearing, and I used quality parts here, EDC green stuff and EDC slotted rotors.
A few questions:
  • I made the assumption that this was related to the brake-pad/rotor swap since that's when I noticed it. If the rotors aren't hot and the pads look ok what else could it be there?
  • Could this noise be coming from the slotted rotors? If so why isn't it a constant hum?
  • What else could be giving this humming?
  • Could this be related to my lift?
  • Wheel bearings on the way out?
Some things about my truck:
  • 1500 4x4 (electric switch)
  • 6" BDS lift
  • 35" toyo rt tires
Are you sure its not the tires? Those are pretty aggressive. Run your hand over them to feel for cupping.
I didn't even think about the tires. I just did but it's a little hard to tell since there is a fair amount of space between treads. I did look and it looks like there may be come cupping going on. I may need yet another alignment. Thanks man, I think that may be the issue.
    Afennell19
    Afennell19
  • Who's Online   3 Members, 0 Anonymous, 871 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
