i need opinions
i was wonering if you need to drill holes to mount aftermarket speakers in an 01 chevy ext cab and how manyof you amp the speakers in the doors also how would a free air sub sound behind the back seat?
I think you do. Friend of mine put Boston components through out his truck. He had to use some supplied self-tappers and even cut some metal away for them to fit in the stock openings.
I have MB Quart (components) in the front doors, and Infinity/Infiniti (whatever) in the rear doors. Neither required any cutting, and while self tapping screws are great, a lot of care should be taken when using them. It's pretty easy to poke a hole in that brand new $500 speaker.
Mark your holes, pre-drill them (about half the diameter of your self-tapping screws), and then mount the speaker with the self-tapping screws.
As far as free-air subs, I have never heard one that sounded decent enough to put in anything I owned.
There is quite a bit of space behind that seat, but keep in mind that when you lift the seat bottom, the base of the seat back moves toward the rear of the cab, effectively halving the amount of room back there.
You might be able to fit some 8" subs back there in truck boxes, but I doubt it.
Best bet is to just bite the bullet, and get one under the seat, or get a JL Audio Stealth box that replaces your center-console with a 10" sub....But those are kinda pricey.
Just my .02
You are going to lose bass when installing aftermarket mids and tweets.
Reason being that they are purpose designed for mid range, and high range.
The stockers were designed to put out all across the sound spectrum, and while they do their job, the sound quality suffers because of it.
If you go with aftermarket mids and tweets, you will be amazed by the things you now hear that you couldn't before, you will also feel the hole in the music where the bass needs to be.
Here is a post with my stuff in it.
Yup, my mids and tweets are amped. :thumbs:
I don't really remember now. I will look for my reciept tomorrow, and let you know if I find it.
I do know it was under $200. Without the subs, of course.
I want to say around $129 + tax.
I ran wires right to the speakers. Also as far as boxes go the JL audio stealtboxes are sweet. If money is an issue look into the JL Audio vantage boxes. Same idea as the stealth box but its made of super thick abs. The sound and design quality are top shelf. I have a sub thump box in my truck and the workman ship and sound quality are terrible. I would not recomend that box to anyone. As soon as JL has a box for my truck the other is going to the dump!!
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
