Window Vent Visors 2 door reg cab
So far I've been unable to get Window Vent Visors that will fit.  AVS ( Lund ) makes most out there but their design wants you to pry back the plastic cover at the front of the window just behind the mirror to slip in the taped flange .  No way , the cover is tight up against the door.  Anyone know of a company that makes something that fits without busting stuff ?
