Hi, thanks to all those who post her for the wealth of information provided.
I am almost the proud owner of a mint condition 92 TopKick C6000 with only 50k miles and  a 7.0L motor and Allison transmission. However the final part of the transaction is held up because of an issue we cannot fix. The truck had not been regularly used for about 9 years, but had been garaged by its 20 year plus owner, and would start easily and run, but cut out and then not restart until some later time, sometimes quite quickly, sometimes the next day. We have done some work in narrowing down the issue, but also in getting a few things in tip top condition anticipation that it's going to run and be used. The fuel filter was pretty plugged up so that was changed along with the in tank pump as that had a dirty and clogged filter and he flow was low. I checked inside the distributor and the ICM was a bit loose and one of the wires on to it was not too secure as the clip going over the tab was resting too high. Decided to change the ICM anyway and managed to get the plug latch to hold securely by using a cable tie to hold it down over the tab on the ICM. Having got it all together it fired right up and sounded fantastic, before the poor fuel flow had it sounding asthmatic. We were getting all excited and ready for a victory test drive when on closing the hood the engine cut out and would not start, it would crank, but no fuel was coming from the injectors, although the pump was running and fuel spurts out of the line at the filter if removed, much more vigorously than before the work on the pump and filter. This is what we battled with yesterday the truck would run, then die, then randomly work again when we took it around the local roads. We noticed that stopping often coincided with hitting a bumps in the road. Suddenly it decided it would go again after stopping today, so having noticed it had stopped once before on closing the hood we decided to test that theory to see if it was just a coincidence, sure enough a very gentle closing of the hood made the engine falter, with a mildly harder close the engine stopped dead. Same problem, engine cranks, has a spark, no fuel at the injectors, fuel pump running. We have checked all the wiring across the top of the firewall that is close to where the hood closes, it all looks like new the outer sheath is unmarked  and even pulling that back to inspect all the wires, we could find nothing. Looking at the maxi fuse panel there is nothing loose all the fuses etc. are as clean as the day the truck left the factory, however there are two relays mounted either side of the large fuses on the same bracket that holds the fuse box to the firewall. I have searched and searched to find what these do, to no avail, I'm wondering as the hood drops very close to the cover over them and the fuses if one of them is faulty and the slight impact is causing a problem. While we are close and now know why bumps in the road were killing the engine, presumably by jolting the hood, we couldn't get it to start again before we had to quit for the day, we felt as if we could get it running by wiggling some wire and tapping on the relays we would find whatever the issue was. Right now we are stumped other than something to do with one of the relays, but we know not what they control. Is there anything behind the dash that could be affected by hood closure? when we are closing the hood we are not slamming it, we are lowering it gently so the impact is very mild, not dropping it from a great height or anything.
Any suggestions greatly appreciated.
The Truck fired right up this morning again, it seems it must be the Fuel pump relay from reading general internet threads on similar problems on various vehicles. However cannot find anywhere where it is located, I'm guessing its one of those on the firewall hence the hood closure creating the  "bump" to make it fail once it gets hot. Does anyone know where the fuel pump relay is located? I'm wondering if it is inside the truck on the firewall somewhere.
Edited by Redhawk4
  • 2 years later...
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   3 Members, 0 Anonymous, 4,481 Guests (See full list)
    • I was around and remember that era very well, so I'm calling b/s on that statement. If they were that bad no police department or taxi company would've bought a single one ... but they were used in both services (and fire) for DECADES. They were bulletproof and proven. Even the early 21st century ones weren't too bad! The early models were legendary.   Mine is proof, but people like atlas are blinded by agenda and refuse to believe facts right before their very eyes.   Even decades after they were built, a new generation started driving them, posting all their builds and shenanigans on Grandmarq.net and Crownvic.net. The failures would show up then, since they all were deep past 100k-150k miles by that point, and younger drivers tend to be a little aggressive, especially with vehicles than can lay a one-tire fire for as long as you hold your foot in it. They've more than proven themselves over the decades.   The only thing that'll really take them out is road salt. The bodies and sheet metal were garbage. A victim of the cheapout FoMoCo and GM have been partaking in before then, and since.   Today it's the stuff that counts - the undercarriage that rots away first!    GMs Caprice was no slouch either. Reliable as a stone ax - the opposite of what they build now.
    • Let me know how your vehicles do in 10 years. You don't know ******, kid. 😂    There's a reason that Panther platform was used as police, fire, and taxi service for DECADES ... long before you were born, apparently.
    • If your connector also has a big lever to get the connector on and off, you don't want to force the lever either way, as it becomes a bigger problem if you bust the lever or the mechanism it works.
    • It's just useful to disconnect the battery to prevent odd shorting out when unplugging/plugging stuff together.  I also  touch the two cable ends together (after disonnecting) to drain the small amount of stored battery energy in various modules.   I believe the main system where you need to be more concerned with, so you need to do the above and then wait some time, iss when you are working on the air bag system, to prevent inadvertent firing of the air bags.   The in-cab switches are just that, plain switches, it's generally not a problem to swap them in/out.  For my '12, I'll get an error message on the dash if I power up the truck w them unplugged, but that's it (power up= turn the ignition on).   The ITBC located above the spare tire is a computer that manages the trailer brake system.  That is probably more important to have the battery disconnected.  It does have to be programmed to the truck, either before or after it's installed, for it to work.  For my '12, I had a very hard time reinstalling the main connector to it (IDK if yours is the same or not), it turned out the silicon seal was jamming up, preventing it from going on all the way.  I finally got it fully installed by lubing the seal with a bit of dielectric grease, then it slid on and latched in place easily.
    • JR ! I just got the truck back from the Dealership today . The technician did a cold remote start on the truck this morning and it made the noise . It was determined that it was a starter issue and replaced it under warranty . Of course   it did not make the sound after a new starter was put in because the truck was not cold . We will we see what happens tomorrow morning when I start the truck cold  . Keep tuned !   Oh I found a video on YouTube of a cold start and it did the same thing your truck and mine do , I will see if I can find it and post it up
