Starter terminal replacement
Hey so have you guys ever had any luck changing a terminal end on a starter positive lead? mine broke off and i don’t want to replace the whole cable and can’t just cut off the end either cause there’s absolutely no extra cable
To be safe, follow electricians training and rules, you should cut off all the damaged ends to get to good clean bright copper. If you do that, the cable might not be long enough. The terminal then needs to be crimped on, with a significant amount of force, which you might not be able to do up under the wheel well.
I recommended running a new wire.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
