My 2009 ly6 blew up at 248,000 I had my mechanic buddy drop a low mile 2010 l96 in it.  Now I'm getting p0172 code for running rich on both banks. Truck seems to run fine. What do I need to do? Got about 100 miles on it so far.
The L96 injectors may be larger than your old LY6 injectors. The L96 is flex fuel so they are larger than the non flex fuel injectors.
Your fuel rail will be fine, just swap the injectors back.
Edited by CamGTP
I think I'm going to go ahead and try to swap the injectors. I've read this on other pages as well...mostly people theorizing. it's very hard to find any information from people that have actually done this swap. One other source I found was reporting problems with running too lean. My truck seems to run excellent. What's the worst that can happen if i keep running it this way?
If it ran rich all the time it will burn through way more fuel than normal and slowly kill the cat converters because of the extra fuel running through them.
I would say swapping the injectors will help a lot.
Edited by CamGTP
  • 8 months later...
Sorry I never updated. The injector swap fixed it. Ly6 to l96 was direct bolt in. Very easy swap just had to use ly6 injectors on the l96
    Sdid
    Sdid
  • Who's Online   3 Members, 0 Anonymous, 1,482 Guests (See full list)
