What up peeps. So I am new to the lift game and I am having trouble going back and forth between lift kits and wheel size. I've seen the sticky wheel post and the tire size but I haven't found what I am looking for so I was hoping to get your help from your experience. There is just so much to consider when you look at lift high, wheel size/width, off set, back spacing. I am looking for that 'just right" look.
I have a 2019 Iridescent Pearl White high country 6.2l 4WD and I want to put 35's on it. I was looking at the ReadyLift 4" SST kit with 35x11.50x20 Nitto Ridge Grapplers on 20x9 Bronze Fuel Rebels.
The ReadyLift Kit says 0 offset but the 20x9 wheels come in 1 or 20 offset. I dont want the tires tucked in the wheel well. I am ok with them sticking out a tad bit. Do I need spacers? Do I go 20x10 and cut? I've seen the black one that custom offset did with 20x10 and 33's with a -18 offset on 2.5 lift.
What is the feedback around the ReadyLift Kit? I considered the 6" kit to get 12.50 tires and 20x10 wheels but I ruled that out because I figured the 6" would give to much wheel gap between wheel and fender.
I know everyones experience is a little different but I appreciate all feedback. I've read where the ReadyLift kit is good and I've read where the geometry doesnt add up and your CV's are put in jeopardy.
Just looking for some guidance.
Figure stock offset on 9" wheels is 24 or so so you would be pushing the wheels out about an inch. I've seen people fit 35x12.5s on stock wheels with a 3.5" lift. But going 11.50 wide wheels instead of 12.5 might give you just enough clearance
On my denali, I have the stock 22s and will be doing 285 55 22s with a bds 4" and will clear no problem
I have the ReadyLift SST on my AT4. Adds 2” to the OEM 2” lift so I’m at 4” total. I did change the UCA which really helps with geometry. Over 3k miles so far on this setup and no CV or CV boot issues or wear that I can see.
Running 20x9 with 0 offset. 305/55/20 (33x12.5)
Poke is about 1-1.25” with no spacers. 5e5abaf46707242132652b6b15fdcfa1.plist701e03be73e9f2389d5442beff5979d6.jpgb9b13fe5a27a134330fd0cafadac25fa.jpgb6292247b72bcbedcdd48cb80be79758.plistdacee03077e145ea558b8a21f52f23d0.plist73b0e751944f73c084a14f331f9d3045.plist
@loud_pipes I just realized you're running at 12.50 tire. So you have no rub issues? From what I was told I needed a 20x9 and an 11.50 tire. On 35's, maybe thats the difference?
Edited by Cobra003
[mention=219399]loud_pipes[/mention] I just realized you're running at 12.50 tire. So you have no rub issues? From what I was told I needed a 20x9 and an 11.50 tire. On 35's, maybe thats the difference?
Yep, that’s definitely the difference. You need 11.5 on 35’s. That’s specifically why I went with 33s - I wanted the extra width of the 12.5.
20x9 +1 offset Fuel Tech with nitto Ridge Grappler 33x12.5
0 offset is basically  the same as 1mm offset ( only 1mm difference) lots of rims offer that offset and not actually a true zero just so you know.
[mention=125934]Dirtbiker[/mention] Thank you. I looked at fuel's website and they show 20x9 is either a +1 or +20. But the 20x10's go to a -18.
[mention=204031]BlackRST[/mention] Did you do a lift or is that stock?
That's with a 2" readylift level kit up front. Sits level... .125 difference front to back. I highly recommend that kit based on quality and finished product specs. I didn't want to go with a full lift because I daily this, with my fiancé and 2 big dogs I don't want them jumping in and out on a lifted truck as they got older.
  • 6 months later...
any issues with the readylift level? Trying to decide between readylift bottom spacer or the rough country top spacer.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 973 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
