steering column noise
I have a 2006 GMC 3500 and the steering column is making continuous rattling noise.  I have had the intermediate shaft serviced twice over the years and I do feel and hear the clunk which was present before.  Now along with the clunk, there is a rattle, as though there is another shaft of some kind loose.  Anyone else had this and will replacing the intermediate shaft take the rattle out?
Bill
I have a ‘13 2500 with same issue. I’m thinking it’s the steering column bearing. It’s made of GENUINE plastic. Doesn’t appear to be difficult, just my old bones won’t let me flex enough to change myself. Steering is tight and responsive. Only noticeable on washboard type roads.
I have had the intermediate shaft serviced twice before by the dealer where I bought the truck.  They admitted to me it is a poor design, but GM has failed to change it.  The GM tech bulletin they used for the repair was said to, "grease the shaft!"  I've been told it is a very hard and heavy grease and will stop the clunking, but the clunking will return in a few months!  Now I have not only the clunk, but a very annoying rattle.
Yes, I also think the plastic bearing can wear out.  I am thinking about buying both a new bearing and a shaft.  Like you, I am not young any more and crawling around under the dash is not as easy as it used to be.  I also watched a You Tube video where the guy replaced the bearing.  He said it took him an hour and a half, as the old one was hard to get out of the shaft tube.  It might actually be easier to take the whole steering shaft out of the dash and rebuild it on a bench.  Oh yeah, he did say you have to be careful about some small spring that can either brake, or come loose if you work on the shaft in the truck.  He secured the wheel with a ratchet strap so it would not turn, or move while he was working on it!
Bill
    Camyon
    Camyon
  • Who's Online   6 Members, 0 Anonymous, 1,204 Guests (See full list)
