Battery light
06 2500hd with 6.0. Battery light came on the other day and will not go off. Battery sits at 12.4v drops to 10.3 while starting and alternator is putting out 14.7 at idle. The strange thing is that it’s acting more like the light is not turning off all the way. When I first start the pickup it is bright then gets dim. I just noticed as I walked by tonight it is still dimly on with the pickup parked and keys in the house. Any ideas would be greatly appreciated
I would physically take off, clean, then reassemble the power and ground connections between the battery, engine and alternator.  And perhaps put an ohmmeter across the ends of the main power wire from the alternator.
