2019 Silverado 1500 8 Speed Hot Temps?
Hi, new to forums completely so hopefully this is in the right spot. I recently purchased a 2019 1500 5.3 z71 8 speed with 20,000 miles on it. I am running a 3” lift and 35x11 goodyear wranglers. Took it on some dirt trails today, nothing technical at all, a subaru could make it. I watched the transmission climb to 240 degrees and it didn’t go below 200 until I got back to the highway.
My buddy was behind me in his 2011 1500 5.3 z71 6 speed with 120,000 miles on it with a 6” lift and 35x12.5 Ko2’s, no aftermarket trans cooler. His temp never went over 190.
This seems extremely high and moreover strange for a new truck. Any ideas what’s going on??
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
