Driver/passenger side fuse box questions
SARNCAN
I want to install dash cam and accessories to my vehicle, and I have some questions regarding 15+ Tahoe/Yukon fuse box.
1- Is fuse type used Micro2?
2- Although that many spots shown as (empty or spare), fuses cannot be hold there and I guess no metal contact is there. So it is useless.
Any suggestions? Would like to use a specific spot for each accessory, not to share fuses. If so, what fuse should I share as a safe option? Such as sharing a heating steering wheel fuse taking in consideration Amps and Volts.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
