Having a lot of trouble removing this connector on my 2020 Silverado LT. Any tips or suggestions? Thank you
Thank you. I have the red tab pushed out. However, both plugs don't want to budge when depressed. Not sure if there is a tool or something I can use to assist with this. Thank you.
  • 7 months later...
We’re you able to get it free?  I have 2020 Trail Boss that I am installing factory fog lights and I am having trouble getting it apart also.
I just had this same problem, but figured out that after you slide the red connector all the way back, you pinch at the rear (top and bottom) and it will slide right out.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
