Okay so every time I now turn my 2015 Chevy Silverado 1500 on the stabilitrac light comes on but the goes off. In all the time I’ve had it I’ve never had this pop up. It’s not staying on just coming for for a few seconds and then going off?
any ideas??
It might help to proofread your note and make it read more clearly.
Have it scanned for codes.  When the light comes on or it says disabled, there will be some sort of freeze frame or code(s) stored in the truck's various computers.
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 683 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
