The cable broke on my 2013 2500HD rear power sliding window that opens/closes the window. My opinions were $450 repair at the dealer or do it myself for the cost of a new regulator for $85 from Amazon. Took me about 3 hrs to complete and learned a few things along the way that I thought I’d pass on for those that want to tackle this project.
1. Have someone help lift the rear seat out and put back in. I was able to do it myself but it was a pain in the ass as it’s difficult to line up the rear seat hooks and floor bolts alone.
2. Do not remove the yellow tab holding the springs down on the regulator until you have the cables completely connected. And do not install the regulator until all cables are connected.
3. To remove the cable from behind the center seat belt guide (not removable), I used the tire iron to insert between the cab wall and the metal guide to remove the old cable and install the new one. Be careful where you pry though as the window frame is plastic and could crack if not careful.
4. Although the GM instruction says to connect the passenger side cable first, I found connecting the drivers side first worked best as it holds the window in place while pulling the passenger side cable to connect it.
5. The cable will seem extremely short but if you keep pulling on it, you’ll eventually be able to slide it into the connection. Having needle nose vice grips and another pair of hands is the key. While one person pulls on the cable, the other person can help guide the cable tip into the window connection. Don’t have your 23 yrs old college graduate daughter help you, it doesn’t end well.???
Otherwise, pretty straight forward and really only requires a few tools, 18mm long and short socket, 10 mm wrench/socket, needle nose vice grips, panel removal tool (not necessary as all panels can be removed by hand, but made it easier)
Hope this helps the next person save time and lots of frustration. Sorry didn’t take pictures.
  • 3 years later...
Sir, I commend you (I hope you still see this 4 years later). I don't usually create an account to reply to stuff, but this is exceptional.
My rear slider broke about a month after I got my brand new 2013 GMC Sierra 2500HD, and the dealer replaced it under warranty. I remember looking at the invoice which had the before-warranty cost (then zeroed out), and I remember gulping a little. Google search suggests that it would have run me at least $450.
I'm somewhat mechanically inclined so I found the Geniune OE part and ordered it and went looking for tips, and thus found your post. I followed your tips and the install went smoothly, in a very reasonable amount of time.
When the dealer's monkeys originally replaced the regulator in 2013, they failed to replace the plastic trim behind the seat. I found those pieces under the seat. But they also dropped a very nice 18mm impact swivel socket back there so I called it even. Eventually I gave up on the trium pieces and tossed them in the trash, because it was a minor cosmetic thing and I found I didn't care. As a result, I only had to remove the smaller seat on the passenger side, after removing the two 10mm bolts attaching it to the big seat, to expose the regulator. The dealer's monkeys had cut the insulator panel and folded it down to expose the regulator, so I didn't have to take that piece off either. So I guess their sloppy work saved me some time and effort today.
Anyway, my rear slider is now put back together and working proeprly, and I sprayed a bunch of silicone lube in the tracks and on the cable, to reduce tension and hopefully avoid a repeat.
    Frank V
    Frank V
  • Who's Online   7 Members, 0 Anonymous, 1,242 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
