I've been running premium since day 1. Dealer still has no clue what's going on and they've had it a week.
Sent from my SM-G988U1 using Tapatalk
I have not but I imagine that would work as it seems to either be something to do with the cylinders going into eco mode or the shifting is occurring a little too early so it bouncing.
Picked it up after a week at the dealer yesterday and they now want to hook up a laptop and drive it around for several repros.
I thought about using the Range Technology module to disable the AFM/DFM....
I'm not sure how relatable this is, but my wife's Honda Pilot does the same thing and its a known issue with similar year models.  A TSB was issued by Honda stating that the transmission fluid breaks down prematurely causing a surging effect when driving, particularly under light load.  I haven't researched the specifics on the matter since her vehicle is past its warranty period and its not a big deal to her, but its still bothersome enough to me that I was curious enough to check on it.  Maybe this helps, maybe it doesn't, but good luck in your endeavors either way.
Well after a week in the shop they still have no idea what's causing it. The next step is for me to apparently drive around with a technician who has a laptop hooked up to the truck
I noticed mine was doing that the other day again so I put it in manual 9 and it stopped.  I believe that also prevents it from going into anything but eight cylinder mode which is probably where the problem is coming from
Whelp, what do you know. I unplugged the range technology Auto stop-start and the RPM bouncing is gone!
  • 3 months later...
I unplugged my range as well. Tachometer stopped bouncing.
  • 2 years later...
How do you in plug this feature my 2021 chevy Silverado 1500 is doing the same thing plz help
    250.6k
    Aries68
    Aries68
  • Who's Online   1 Member, 0 Anonymous, 283 Guests (See full list)
