I have a 1999 Sierra. I don't know these parts very well and what I do know ive learnt from you tube. Can I just buy the crossover or do I have to buy the fuel rail also? Just need to replace the crossover attachment .
Last I checked the whole fuel rail has to be bought and I'm not sure if they still sell those new through GM.
Junk yard might be the best bet or ebay/car-part.com.
I saw a few on eBay but was hoping I didn't have to replace the whole thing. Seems like alot of work for someone that doesn't know what their doing. Hopefully they have a step by step you tube video I can follow.
