I'm about to replace the stock Rancho Shocks on my 2017 Silverado. The back is straight forward. On the front, can I replace just the shock or should I replace the whole assembly? I stopped at the local mechanic this morning to see if he could compress the springs and install the new shocks in the struct for me. He suggested I replace the entire assembly with a quick struct. He suggested that because they would come with new bearings and a new plate. Does this seem right? Can I replace just the shock?
Thanks
Fronts are STRUTS rears are SHOCKS. You can replace just the front struts and keep the factory spring. I suggest purchasing new top plates for the front struts. Suggesting a quick strut is meh. Your better off buyin into the lift and level crowd even if you don't need the lift and set to zero.
  • 3 weeks later...
Yes you can replace only the shocks in front. But definitely have a pro do it. Even some wall mount coul spring compressors have a hard time with the fat truck springs
By the way, the fronts are Coil-overs, not struts. Struts also contain some steering knuckle integrated. Coil-overs do not
    Aries68
    Aries68
  • Who's Online   5 Members, 0 Anonymous, 376 Guests (See full list)
