Has anyone received their order from Shock Warehouse lately? I ordered Bilstein 5100's, for the front of my AT4, over 4 weeks ago. They took my payment right away, and haven't heard from them since. They won't answer the phone, emails, or the live chat. Getting ready to do a charge-back on my card.
I used them about 12 years ago with no issues. Even had to exchange one Bilstein shock, still no issue. But that was 12 years ago so who knows now
