Has anyone found front mud flaps for the 2019 4500-5500? I went to the dump and the front tires throw mud all over the boxes that stick out past the cab, seriously every truck bed on a commercial vehicle sticks out past the cab why would GM NOT put front mud flaps on a truck like this??? My 2003 Top Kick came with them as standard. No option I have seen anywhere for 2019. This seems to be a must to keep the bed from being sprayed with what ever your driving through.  The F550 comes standard with front  big wheel lip extenders that protect well.  Seems like this should be an easy fix.
  • txab changed the title to Mud Flaps
I agree with you completely.  I'm looking for front mud flaps for my 2019 4500hd as well.  Hopefully a manufacturer, or GM, will make something available soon.
  • 4 months later...
  • 3 months later...
Hi guys, here's a link to front mudflap set for Silverado 4500, 5500 and 6500. These will fit models made after 2019. Southland made these mudflaps for the International CV model but later found they were a fit for Chevy. Here's the link to their site
Edited by starwheelz
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
