2000 silverado 4.8L. Brake lines rusted out. Vehicle sat for a few months with the lines cut from the abs pump. I lost all fluid. ABS fuse was pulled. Fast forward to the repair... I replaced lines and tried to bleed the traditional way and got nothing although I had pumped about a quart into the system.
My MC was corroded and old and I figured that was part of the problem so I replaced it before resorting to towing it into a shop.
Afterward I was able to bleed the brakes at all 4 corners with the 2 man method. Most of the air seemed to escape from furthest rear. I used another quart or so when bleeding.  I then reinstalled the ABS fuse (no lights now on dash). Brakes seemed a little soft after doing it but I went on a gravel road and made some hard stops and it seemed to tighten it up afterward. I did not bleed the system again.
So my question:
Is it impossible that my brakes are bleed correctly as they stand now?
I ask because I read the warning about needing a scan tool to bleed the ABS to be able to get anything from the calipers at all.  I am confused as it seems satisfactory now.
Thanks for the reply. Im second guessing myself after reading all the posts about the abs module needing the scanner.
I also read about cycling the abs on a gravel road which i tried to do. However i am unclear exactly how the abs and truck should respond in such a case. The truck just came to a stop, no skidding... the pedal was softer than it was when i was normally stopping on pavement.  Also no abs light came on like i thought it might if i activated the system.
Edited by xrmik
So my question:
You also have to bleed the ABS system and that is done with a Tech-2 or equivalent.  Replacing all of my calipers and draining the old fluid out, I went through 6 quarts of brake fluid after doing the traditional and ABS bleeds.
I bled it a second time, after doing the hard stops on gravel and the pedal seems great. In fact it a noticeable difference than how its been the last year or two with the rusted out lines and corroded master cylinder.
If there was still air in the pump, would it be immediately apparent by pedal feel?
Edited by xrmik
I don't know the answer to that one.  @CamGTP
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,142 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
