Ok so there is no longer a misfire. It has a slight hesitation under load it does go up to about 35-40 mph now since fixing the exhaust. Still can not figure out this hesitation/big down....I'm thinking either faulty MAF or IAC
IAC stands for Idle Air control, it does not function above idle speeds. So not likely that.
As a test you could unplug the MAF and see if it runs any different. It should default to a MAP based control instead of the MAF/MAP combo.
    DM22
    DM22
  • Who's Online   5 Members, 0 Anonymous, 2,022 Guests (See full list)
