     I have a 2018 Silverado with the back up camera on the tail gate.I was thinking how nice it would be to have a back up camera on the license plate frame of my trailer.That way,I could see behind my trailer when I am using it.Does anybody know if it would be possible to buy a license plate backup camera and display what it shows instead of the tailgate camera when using the trailer? I am thinking that it "might" be possible, but I am not at all familar with this.Thanks.
  • 4 weeks later...
I'm looking at getting a license plate camera with rearview mirror display, finding a way to have constant power to it, will help with lane changes, as well.
I want one too.
In Minnesota you don't need a license plate on 3000# and under . I have power via the license plate light. I run with my lights on always. Day and night.
( I want the fool about to pull out in front of me to see me coming)
I was planning on using the place where the light is to mount the camera. I want a wireless setup with a separate small screen mounted somewhere on the bottom of the dash . Maybe the ashtray. What do you think?
Sent from my Pixel 3 using Tapatalk
    thefultonhow
    thefultonhow
  • Who's Online   6 Members, 0 Anonymous, 682 Guests (See full list)
