Hello all,
I'm looking to upgrade just the muffler on my 2020 Denali 6.2L. Has anyone done this on the new generation Sierra? I want to keep the cat, flappers, resonators, and just swap out the muffler. I just want a little deep rumble, but I don't want piss of the neighbors either. I also don't want any drone. Not even sure I can do just the muffler using Borla, but I know I can using Flowmaster. Any incite would be appreciated
I have some insight for a bit of a different setup.
I’ve tried both magnaflow (installed ~2 months ago) and now flowmaster (swapped yesterday) cans on the 2020 Sierra AT4 5.3L. Full dual exhaust from front to back straight off the headers.
Sounds great start up on both. But once idling, it’s too quiet. If that’s a thing. I mean I paid for a growl, and it’s there, but it sounds stock at idle. With this 10 speed, any cruising or stable speed, it’s also too quiet for what I was expecting. I’ll have to break this one in a bit. I was expecting something like Borla s-type sound out of the flowmaster, but it’s definitely under that.
My Acura was louder at start up and idle by far, and that was Apex’i Touring, nothing like the massive Greddy exhausts others were using.
I’ll see if I can get you a clip of the flowmasters.
I just had the same debate on my 6.2 and decided to muffler delete it. Man... what a difference. I left all flappers and resonators in. Cost me $75 and sounds incredible. No drone under 80mph and then a very, very slight drone afterwards. The flappers really help. It isn't too rowdy for neighbors in my opinion. Here's a cold start for you. It calms down really quickly after. I would try it out and worst case scenario, you don't like it and stick a muffler back in its place.
I did the gmc performance exhaust on my 19 before it got totaled, I just picked up my twenty and not sure what to do either.  I may just do the Borla touring... we will see.  Your truck sounded good at idle.
As promised.
2020 GMC AT4 5.3L
Cold start up with full dual exhaust, headers to tips. 1 x-pipe, Flowmaster mufflers.
Cold start to idle, thought it was done spinning down, but it actually got even a little more quiet.
It’s doing well, but not quiet as aggressive as the Borla S-type cat-back. It’s in a bit of a corridor, so sound might be bouncing back a bit.
My brother did the flowmaster outlaw. It's definitely not too quiet haha. It's loud on start up and then mellows down to a growl that's just enough on highway and around town until you get on it. It crackles a bit on start up too which is sorta fun.
Thanks. Sounds good. Definitely something to think about
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
