Part of my rubbing problem might have been the fender flares. I don’t think it rubbed as bad with the factory flares and mud flaps.
On 10/5/2020 at 4:19 PM, EZ Money said:
I am planning on running the 2" SST kit with a set of 22x10 Hostile Sproket.  The wheel has a -25 offset.  We are going to use a 295/55/22.  It might rub a little, but can do some trimming.
Looking forward to pics
Wondering how things are with Auto/AWD & the 2” added lift? The info from kit’s manufacturer says that it causes a bunch of vibration and they recommend not using AWD? They suggest 4 Hi and 4Lo, but of course GMC manual says not to use 4 Hi on dry/flat roads bc of premature wear?
2 questions in one : )
Notice any issues with the lift?
Have you gotten to the tonneau cover yet? I am just getting around to putting one on mine. Took it to the dealer because I had a credit through them so I was just going to have them install it. After a couple hours they said there’s nothing that will fit the truck.. long story short I know that’s not true and wondered if you had gotten yours on
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
