It is compatible. But only on the passenger side that doesn’t have the handle assist. If you remove the handle assist, you can use both sides. It will block the Cargo light and the three rear tie down rings. But the swing case comes off easy if needed. It’s really great.
I have the passenger swing case on my 2020 AT4. No issues with my multipro. I even called undercover ahead to confirm and he explained.
Thank you for that !!
I had emailed the company and they said the same thing - compatible on the passenger side, but you have to remove the step assist handle for it to work on the driver side.  I don't think I really have any intentions of using the step assist handle, so I might get the drivers side.
I’ve never used it yet. The multipro brings the step low enough. I’d remove it if I didn’t have a rail installed on top of it already. Dealer installed it for free before I picked up the truck.
