Does any one on the forum run the Kryptonite stage 3 leveling kit with fox shocks? If so what is your opinion on the kit. Good buy or waste of money?
My truck is a 2018 silverado custom double cab. 4.3 V6
I was seriously considering that kit.  Seemed like a good kit and the price seemed reasonable.  Then I decided I wanted adjustable ride height shocks.  The ones in that kit are not adjustable on the truck.  You need to go up one more level in the Fox lineup for on truck adjustables.
Sorry, that was wrong.  I looked at the package again, and they are the IFP shocks, so they are ajustable on the truck.  Those shock go $490 each and the rears are $170 each and the arms are $500 for a pair if you buy it all separate, so $1820 total.  That makes $1700 for get package pretty good.  It would cost an extra $420 on top of the individual prices to go up to the 2.5 coil overs.
Edited by Mike GMC
Heads up you'll need spacers or new wheels with their UCA's. Their rep recommended 4.5in of backspacing to me. Ride and look great
I can confirm this. I did a 2.5” level and Kryptonite control arms and the stock wheels rub the control arm at about half lock of the wheel.
On 10/2/2020 at 6:15 AM, MasonB said:
What wheel size and offset did you go with on your truck or did you go with the spacers?
I went from stock 18s to XD844 Pikes at 20x9 0 offset. Just ordered some small spacers for the front. I feel like the wheels might touch the arms at full lock at certain angles. If I had to do it over I'd go with the Readylift UCA's and tap grease zerks into the bushing housings
For those that had rub with stock wheels, were they the 18" or the 20" wheels?  Maybe it doesn't matter, but just curious.
My stock were 18s, but considering I still have slight rub on 20s with 0 offset I guarantee stock 20s will have major rubbing
Edited by Shea Albers
I had the 20” OEM snowflakes.
  • 3 years later...
Did you rub on the kryptonite uca and if so how much spacer did you need ?
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 720 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
