Hey guys, somewhat new to the board(lurked for a bit and finally joined to ask some advice on a sound my truck was making). Purchased an 18' Sierra back in July and have been looking around at different things I can do to it, just not sure where to begin. It's a 2wd, and I don't really want to put a lift on it; but I'm interested in leveling it(which I know might lift it a bit) and eventually some wheels/tires(as big as I can go without a lift). Can you guys point me in the direction to get started with the leveling kit(s), and maybe an idea of what I'm looking at cost wise for that? Appreciate any feedback
Check this thread out https://r.tapatalk.com/shareLink/topic?url=https://www.gm-trucks.com/forums/topic/239920-new-truck-what-are-some-cool-inexpensive-upgrades/&share_tid=239920&share_fid=33003&share_type=t&link_source=app
Muffler delete is ~$75. Just cut out the muffler and weld in a pipe. Gives the exhaust a nice growl. AirRaid MIT is ~$150. This might increase fuel economy. Do the air box mod as well. Results are mixed in here. But it's cheaper and gives the same effect as a CAI. Level kit is $60. It's not hard to install yourself. Get an alignment after you're done. Paint stick mod is free. If you have a center console, organization addins are cheap and nice to do. Under seat storage is cheap. Can add a train horn for pretty cheap.
If any of this sounds strange just search it in here. There's tons of write-ups.
Sent from my SM-G973U using Tapatalk
If you want a better ride, Bilstein 5100's seem to be one of the more preferred choices on leveling. I swapped my factory rancho's out and have been way happier with the truck. Had a 2" strut spacer on prior which did the job but the ride was terrible with the rancho's. I plan on going one size up from stock (275/60/20 A/T's) in the next few weeks as winter is approaching, the stock SR-A's are complete garbage. Should require no trimming with my wheel setup (20x9, 0 offset) and give it that aggressive look paired with the 5100's.
My 2 cents on performance upgrades... Airraid MIT, drop in filter and air box mod, with a L86 intake manifold/TB (if you have the 5.3) and a custom tune really wakes the truck up on a budget and for a daily. But trust me when I say... once you start modding, you'll never want to stop! ?
  • 3 weeks later...
There's a lot of reading, but there are some inexpensive things to do......
If you look in my album(s), you find my list(s) of things that I've done, am working on, and have planned to do to my 2015 ? and my 2018 ?
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
