I just installed a snowbear snow plow on the truck, plow was about 2k, assembly was about 4 hours over the course of two days.  and the end result looks like this:
Looks great but just no way I could do that to my new truck, I plow a lot at work and our old Dodge is just eat up from one end to the other. Brake lines bust all the time, one issue after the other. Salt is just bad.
Thank you, this plow is kind of whimpy so it should not be too bad. Plus I will be doing my house, my parents, and few friends probably
  • Thanks 1
I don’t know what part of the country your in. But. I will definitely agree with you that plow is wimpy. I hope you don’t have to push anything but 2 inches of powder. That thing couldn’t push 2 inches of heavy wet snow without flopping forward. You will want a Boss or a Fisher after you see how that thing performs in a real snowstorm.
My father in law had boss v plow on his 3/4 and it felt too much of a plow for drive ways and such. This one for home use will be fine. I had a snowsport prior and it was okay. Not the cleanest but sure get most of it out. I sure hope this one do better considering it cost twice as much ?
Will, we got some snow today but it wasn't Worth busting out the plow. Finger crossed we get more soon (I never imagined myself saying these words ?)
so did my first run with the plow today, back dragging was much better than what I expected considering it is a floating plow (no down force) and got my drive way cleared up in about 10 min, the winch is kind of slow but I could upgrade that with hydraulic cylinder in the future. it is still snowing here and I might do some cleaning at lunch or after i am done with work and get some pictures.
Edited by Moend
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,533 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
