I did not have this problem with the same GalaxyS10+ in my 2015 Sierra All Terrain but the damn lag in my 2020 AT4 is so aggravating! Anyone know how to fix this issue?? I have Googled around and have not found the fix
All the vehicles I've ever watched YouTube in with bluetooth has this issue.
It's an issue with codec. I don't know why but it seems a lot of manufacturers don't update it.
My BMW , Tundra and all the rentals I've had. Plus the ZL1 and the Silverado.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 218 Guests (See full list)
