Recently purchased a 2020 Chevy Silverado 3500 diesel. Looking to get some wheels and tires. I want to keep the truck stock as far as suspension. Currently looking at the 18x9 Fuel Mavrick D538 with a +20 offset. Not sure what to do for tires. Needs to be at least load range E because this truck does tow. Looking at possibly Nitto Ridge Grapplers 33x12.5r18 any input would be great. . Will these fit fine? Can I go bigger? What can I fit on this thing? My goal in the end is a beefy more aggressive looking tire and I don’t really want them to stick out much past the fenders a little bit is okay but not much. Any help you guys can give would be awesome.
these trucks come with a 34" tall tire, at least mine did. I would not go down in size.
guys are fitting 35s stock no problem
