You can just trust your shop and replace your rear wheel bearings. But if it were me, I’d try a wheel balance first. By someone who does the Hunter Roadforce balancing. If you have a lot of life left on your tires, Firestone will normally do a lifetime balance for around $60, I think. As your tires wear they tend to benefit from a rebalancing.
roadforce balance has helped a lot of people in past
lug nuts have proper torque?
what tire pressure do you keep?
& what tires?  brand & size
there any noise coming from rear bearing?
or weird tire wear (on current or prior tires)
