Hello folks,
I am going to install a Viair Constant duty On Board Air system.  I tow a 5th wheel trailer, it will be used for tire air top ups, pneumatic tools,  future Air lift 5000 Ultimate air bags. I think I know what I need for this, to run two systems concurrently from the same compressor / 2.5 gal tank. Just wondering if anyone out there has installed one of these and has any insight. I am installing it into a 2019 GMC Sierra HD Double cab SLE.
Might even get air horns ?
Thanks in advance,1782244747_downloadviair.jpg.169f6fc167cc1dd955b0e1819151f645.jpg
Dan
