Do u have a link where u bought these can’t seem to find them
On 11/7/2020 at 5:34 PM, Sonny Durden said:
Hello I installed these yesterday. They look soooo good. Great upgrade for the 19-21 Silverado Custom, Trail Boss, or Work Truck
Hello
can you contact me in email [email protected]
Hey, definitely looking good! I've got the same ones for mine just now, and wanted to ask you how the headlights are still faring? I see you've got them almost 2 years ago so I think by now you can tell if it's worth installing them or not!
Also, did you switch the halogens to H7 led? I am interested in doing that too!
I've had mine in for a couple months and upgraded the halogen H7's they come with to LEDs before I installed them. I used Lasfit LC Plus Series H7s. I tried to order a different model from Lasfit and they asked what it was for and I sent them a link to the headlights since they are not stock lights and they said the model bulb I had chosen wouldn't work and said the LC Plus Series would work. They fit fine and I've had no issues with them so far.
  • 7 months later...
I installed the spyder projector lights today. The worst part was removing the small side fenders to get to the headlight bolts. I broke at least 2 tabs. I noticed the marker lights on top are pretty tight to the fender of the truck all the headlight bolts were aligned there not much room if any for adjustment. The oem lights might of been the same I just didn't pay attention.
Edited by Tcustomsilverado
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
