Hello I installed these yesterday. They look soooo good. Great upgrade for the 19-21 Silverado Custom, Trail Boss, or Work Truck
Edited by Sonny Durden
Add
  • Like 5
  • Thanks 1
Looks good. Better than the yellow halogens. I surmise the headlights are still used as the DRL's instead of the strips? The only thing I've noticed on Spyder lights in the past is that the LED strips are more of a dim glow and not bright because they are florescent and not LED. Probably because they stay the same brightness day and night and not like the OEM DRL's which are bright (high power) during the day then go to low power at night. What high/low headlights are you running?  They come stock with halogens.
Edited by mafd2
10 minutes ago, mafd2 said:
Looks good. Better than the yellow halogens. I surmise the headlights are still used as the DRL's instead of the strips? The only thing I've noticed on Spyder lights in the past is that the LED strips are more of a dim glow and not bright. Probably because they stay the same brightness day and night and not like the OEM DRL's which are bright (high power) during the day then go to low power at night.
So the LED strips are not used as DRL. They only come on when you remote start the truck or when you actually turn the lights on. Since they are plug and play they utilize the low beam as the DRL just like the normal halogen lights
The strips are CCFL (florescent) and not LED. What high/low headlights are you running?
Edited by mafd2
So this housing calls for a H7 instead of a H11. It comes with those bulbs. I upgraded the H7 low beam with a LED by Beam Tech.
I didn’t know that they were florescent. They are pretty bright at night
Looks nice. Be sure you get hem aimed correctly. Go on an even slad and use mortar lines on a brick wall or similar to be sure they are same height. If you get flashed, bring them down a tad until the cut off line on the projectors is right. Not sure if you know but LED or HID headlights voids the warranty but I would've changed the halogens myself. Aftermarket LED headlights put out a lot of heat and have melted some housings.
one of first things i did was upgrade to LEDs.....mine worked out perfect as far as cutoff.....i used a wall like dude above said and almost identical, haven't been flashed once in 6 months and my truck sits pretty high....
my neighbors business upgrades sprinter vans into fancy overlander type vehicles and he brought a brand new one home other day and even that had halogens......those are 50-80k though this one was probably closer to 50k......still cant believe halogen even exist anymore
  • 1 month later...
Do you have a photo of these lights in brighter light turned off? Trying to decide between these or HID retrofit
  • 3 weeks later...
I like the look of these pretty good! Spyder quality has come a long way since I had a set on my 2009 Silverado.
I hate that GM went back to halogens on some T1 trims. Every K1 produced 2016+ had bixenon projectors - even the work trucks. Now someone who spends a lot of money on a Custom or Custom TB gets halogens? Bean counters at it again...
I think those look pretty good. Sort of have the 2500 style to them.  I'm glad to see aftermarket supplies jump on new opportunities.
I hope they are good. It wasn't exactly easy to replace them. LOL
I don't want to do it again anytime soon.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
