I got a po440 code and i replaced the gas cap and the service engine light went off. A few weeks later it comes back on again. The fuel pump is new so i figured that sensor is fine. Po440 is the only code being thrown so what could this be ?
dave is correct , you have a large leak ,  check for broken evap lines, , then remove your purge valve and blow through it both ways, next do a continuity test on vent valve , purge valve is always closed and vent valve is always open  .good luck
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 541 Guests (See full list)
