Not concerned if it isnt dead level. $400 for parts and labor for over strut or $40 and my free labor for under, is the 1/2" worth the $350? Going to run 275/65r20 on stock rims so rubbing wont be a problem either way.
Do not run lower spacers, they interfere with CV boots.  Make sure the kits you’re looking at are Trail Boss specific.  Go with a reputable company like Readylift or Rough Country
I did the 1" under no problems at all the only way the bolts will interfere with the CV shaft boot is if you install the bolts from the bottom and nuts on top. I have over 3,000 miles on mine and no issues. Make sure you get an alignment done after. Even if you only go with the 1". I thought I would be ok but the toe was off and the tires started to feather on the outside a bit.
4 minutes ago, Firehawk T/A said:
I did the 1" under no problems at all the only way the bolts will interfere with the CV shaft boot is if you install the bolts from the bottom and nuts on top. I have over 3,000 miles on mine and no issues. Make sure you get an alignment done after. Even if you only go with the 1". I thought I would be ok but the toe was off and the tires started to feather on the outside a bit. With the 1" kit I now have 3/4" rake.
Edited by Firehawk T/A
23 hours ago, Firehawk T/A said:
Thanks and I may have to borrow the red caliper idea. Looks great on your truck.
    scotthvac.net
    scotthvac.net
  • Who's Online   1 Member, 0 Anonymous, 458 Guests (See full list)
