I have a 2016 Tahoe with 110,000 miles that is misfiring on number 8. It has been doing this intermittently for the last 10 months. I have had it at the dealership 6 times for this problem. The first time, 10 months ago, they replaced the plugs and did a "engine and injector cleaning" which did not solve the problem. I can go weeks without it misfiring and then it will do it 2-3 drives in a row. Most of the time the code does not stick but rather just flashes. It is currently at the dealership and this time the code light was stuck on. My frustration at this point is that while the dealership has the data that it is misfiring, they keep telling me they cannot recreate it and so don't know what is causing it. They have had the car for two weeks at this point and the last four times it has been in for this they give up and tell me they can't figure out what is wrong. At about 30k miles it was randomly misfiring and they replaced all the injectors as a warranty issue.  I am getting ready to go to a different mechanic/dealership but wanted to know if anyone had any insight for me. I have attached the mode 6 data from my code reader that triggered the engine light this time.
I feel like a broken record telling hundreds of people this every month ... but GET THAT THING OUT of the dealership!! You're way out of warranty, and the way GM corporate's trickle-down business works, you will be paying THOUSANDS with no solution (except for a shiny new POS for $60-LARGE out on the lot they'll gladly sell you ...).
At the mileage you're at, I'd bet that you have a partially sticking AFM lifter. Ticking time bomb waiting to stick solid and misfire constantly. They all do it eventually. Of course there could be leaky intake gaskets, wiring issues, and several other things that could cause this. You NEED to get that thing out of there and into a reputable INDEPENDENT garage. trust me on this. I see and hear this same old story play over, and over, and over again year after year. These days dealerships seem to be on the same level as politicians. Insanity ...
Edited by Jsdirt
This will be a bit more positive message.  Personally, I would rather have the shop tell me they can't duplicate the issue than start throwing "best guess" fixes at it.
Having been a mechanic, I would tell the customer that I was not able to reproduce the issue if the issue did not happen.  I also would explain that without experiencing the issue it would simply be a guess to offer a diagnosis. I would suggest they take their vehicle and pay attention to what they did to make it appear.  Once they find the way to reproduce the issue, verify a few times that those steps cause the issue to return then bring the vehicle back.  To me, the only thing worse than being wrong was getting caught when wrong.
That's what a trip to the dealership usually leads to - thousands of dollars in parts fired out of the parts cannon with no resolution! Like I said - same old story over and over again.
Even service data tells you to grab a good part and replace the part - if it works, it's good! No in-depth diagnostics. "Does 'part x' work? Replace ECM" - insanity! Good way to keep GM stockholders and their vendors happy. GM doesn't even like backprobing connectors! How the hell can you even troubleshoot without back probing a weatherpack? Plus they don't pay the techs for the time required for any in-depth troubleshooting (that isn't even taught there to begin with), so why would they bother? I wouldn't either. I don't know of a single person who will work in this field for free. It all starts at the top, and rolls downhill unfortunately. You know the game. Gotta play it if you want to eat that week.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
    • It's the Middle East conflict that raised prices, not AI. But nice distraction.
