Does anyone make a fender molding for the Silverado that is similar in size to what is on the Sierra?  Don't need anything that really sticks out any farther, just like the look. Didn't realize before I bought that they are completely different fenders and beds in the Sierra and that you can't just order the factory flares and throw them on a Silverado.
Unfortunately that is why the GMC is a premium marketed brand above Chevrolet. They diverge more and more every refresh cycle.
Myself, I traded my suburban for a Yukon, and it’s true. GMC has better sound deadening, touchable interior parts, and softer seats. I wouldn’t have believed it before until owning both versions of the K2 platform in different brands.
I believe it, I just didn't like the premium price.  Drove both, the Sierra is definitely the better truck. I ended up with a Silverado WT and I'm just adding the parts that I care about or want aftermarket.  Going to end up being WAY cheaper and give me something to do.  I think it was around $6-8k more for a Sierra in the same year with the same miles as my WT.  Obviously there are many things that are better in the Sierra, but for me I only wanted a few of them. I'm one of those people that is perfectly happy with a rubber floor instead of carpet and Weathertech mats.  Also perfectly happy to install a remote start/keyless and radio aftermarket instead of the factory units.
I think the closest thing you will find is the Bushwacker flares. I think they are called OE style, check there site and you should find them.
Edited by SSchup
correction
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
