So after 5 years my truck started to trip out on the touchscreen, changing the radio by itself i took the glove box apart checked the connections and blue plug trued everything i found on youtube and on this forum. After taking my trim off i looked up my part replacement for the screen , found used ones on ebay for $300 used from wrecked all terrians but didnt want the same issue to happen so i tried those gm parts direct websites that are half the price of dealers but in reality are dealers . I called around and emailed some. One that was 500 got back to me said they could not honor that price and they would either cancel or charge me $1000 because they did not make them anymore so i didnt bother with that site . I called another site and it went staright to a dealer parts dept , the parts guy didnt know i was calling from the discount website number but he told me that part was no longer made there was a new gm part number that replaced it and said it was out sourced eithwrway , he said you know what call them and see what they say so he gave me the number to the source . SPECMO ENTERPRISE (248)307-2570 they deal mostly with dealers i just told the young lady the dealer reffered me gave her my gm part#23383730 and they shipped out a replacement NO core $360 shipped cheaper than anyone and it fixed the problem. So wanted to share only advice i would give is pull your trim get your PART# and see if there is a gm part # that has replaced it since then and use the new #. My original part# was 23485743
  • Thanks 1
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
