Hi, I looking to source front diff lockers for my 2019 Silverado 2500HD, I know it has the G80 rear diff but I can’t find anything online about front air lockers? Can anyone give me some advice, I am located in Australia.
Good question. Not sure about Australia....Check out this video on rebuliding front diff. He make reference to "locking front" differentials in the video & sounds like they supply them.
Keep us posted....
How To Rebuild A Front Differential | GM Truck Duramax
Kodiak Truck and Trailer Sales 100 Oakridge Dr North Prairie, WI 262-370-8300 ? https://kodiaktruck.com coupon code truckmaster save 5%
Edited by rav3
I would hesitate to put a real locker in the 8.2" front diff.  Maybe a limited slip would be a bit easier on the small parts in that small diff.  Particularly in the 2500 with it's additional weight compared to the 1500.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
