Hello All,
I’m looking for a coil/strut combination for the front of my truck.
I don’t believe there was much thought put into doing anything difference for the reduced weight and reduced length of the regular cab / 6’6” box. Truck has always been very rough, and thus the nature of it I’m sure. Truck was plagued with the shake from the beginning, but GM refuses to fix. Shake subsided marginally with the addition of 2” level. Then went to Bilstein 5100’s, but the front of the truck on the 1.85” setting is as rough or rougher then factory, back is much smoother.
I dislike the idea of increasing the spring rate tension to give the lift.
is there a smoother more forgiving option for the front of these trucks? Perhaps one proven to the short wheel base? One with lift included would be ideal. However going down this road again I want to be sure I’m upgrading the ride substantially.
On 11/29/2020 at 12:19 PM, James ****** said:
felt the same in my single cab with 5100s and my conclusion was ditching 20" wheels and now the truck rides better than ever
Makes total sense. And I’ve entertained the thought before. But with 285/60/20 duratracs and the general appearance the trucks make 20’s look tiny. I like the OEM look as well.
ive seen the quick lift ranchos but I doubt the quality of ride.
Been here, done this. It's a check list situation.
1.) Factory shocks are digressive this writeup will help explain that.
https://accutuneoffroad.com/articles/digressive-vs-linear-vs-progressive-pistons-shock-valving/#:~:text=The terms Digressive%2C Linear%2C and,5100 %26 6100) are digressive.
2.) Many times the factory alignment will have excessive amounts of caster. Use the mid to lower half of the range as your target.
3.) Any lift done at the coil over limits rebound distance and removing the stops to get it back kills ball joints. Use a knuckle lift and a damper/spring that puts the total stroke at 50-60% of compression.
4.) Allot of that front jar comes from the back half. Ditto on dampers.
I used KING OEM replacement but FOX is also linear and cheaper and very tunable.
    doylej24
    doylej24
  • Who's Online   5 Members, 0 Anonymous, 776 Guests (See full list)
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
