Hi,
Do anyone know if I can change the Mirror LED to something stronger?
I want a company that makes it so I just replace it.
  • 1 month later...
I havent found anything to replace them, but was thinking of adding custom angled mounts from rigid. Considering how my lt trail boss didnt come with power fold, I think it should have enough space. What do you think of this mod?
I think the modification would be better is to modify the LED board inside the mirror only, because the I like the OEM Trail boss mirror, so the change only with brighter LEDs.
I have came with an idea that is to remove the cover and add your own LEDs whatever you want and remove the old one and put a switch for them so you can switch it on and off from your own switch ( that's mean whatever gear you are in ) with brighter LEDs.
For now I have done the switch thing. But I think after testing the OEM in the offroad it would be better to change the LEDs.
