Sorry if this is in the wrong spot.
2003 Chevy Tahoe LS 4 wheel drive. I've had this Tahoe aligned twice at two different shops and both say everything is good under it but for some reason it's still pulls to the right. I think they are something else going on other than the alignment. It has new upper and lower ball joints and new inner and outer tie rod ends. The wheels have been rotated and all the correct air pressure is in all four tires. I don't think the alignment is the problem. I believe it is something else but I cannot figure it out. Has anyone ever experienced anything because it has me so confused right now with two shops saying it is perfect on their machines ? Any help would be a much appreciated.
Thank you,
Greg Hunter
I think I even put new upper a arms on it. Can't honestly remember if I put lowers on it or not. I'll check the wheel bearings as thank. Thank you
Check the wheel bearings and cv joints (if it has cv joints)--a drag on one side could make it feel like it's pulling in that direction.  Also, you might look up the correct factory alignment settings online and make sure that is what your service places are using and you might look in on your alignment services to make sure it is actually being performed.  Last one I paid $85 at a tire dealer and found out later from someone I trust that they didn't do anything.  Normally I watch, but the tire dealer purposely has their service bay walled off and garage door windows covered up.  Now I know why.  Keep in mind that the factory alignment settings contain a range.  A vehicle can be within range and still wander excessively or pull due to road crown.  How do you rotate your tires?  Rears to front and fronts crossing over to rear is the GM preferred method.  Some service places like just doing front to back rotations (if they do them--again, we have caught places not rotating them before) because that is a just a hair quicker and easier for their techs.  If you have a tire or tire(s) with radial tire pull and you just switch them front to back (so they are still on the same side), they will still pull in the same direction.  A road force balancing machine used correctly can diagnose a tire or tire(s) with radial tire pull due to internal belt problems.
Edited by MaverickZ71
Thanks for all the information. Definitely check on everything that you mention.
Thanks again,
Greg
    DaleB
    DaleB
  • Who's Online   7 Members, 0 Anonymous, 1,357 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
