I just bought a 2020 DC LT for the reasons stated above.  I had a 2018 Crew Cab but realized it was just wasted space in the cab as I am by myself 99% of the time.  I also like the full size bed vice the smaller version I had on the Crew Cab.  Most importantly, I got the solid back window vice the slider so no more leaks.  I am loving my truck!
Sad, but I expect even more DC trims to be on the chopping block before long. I'm glad I got my RST as I'm sure it won't be far behind. I rarely see trucks like mine. I much prefer the look of a DC over the CC. I get more use out of the standard bed than I ever would out of the extra rear seat space. Plus, I think CC with the standard beds look kind of goofy. To each their own. This is my third DC Silverado but maybe my last depending on how the future generations are offered. It was hard enough finding a DC with the 6.2 this time around. I'm sure it will be next to impossible next time.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
